How can I download a video without it's audio track, ideally with the ability to choose what level of quality the video will be downloaded in.
Edit: I realize that selecting the quality may be the same as in other questions, but my main question is how to get a video without it's audio.
anonymous2
  • 4,325
youtube-dl is a small command-line program to download videos from YouTube.com and other sites that don't provide direct links to the videos served. To install youtrube-dl in all currently supported versions of Ubuntu run the following command:
sudo apt install youtube-dl
In addition to serving normally formatted videos with an embedded audio track, YouTube also serves videos with the audio and video tracks separated into two separate files. To download the video only without the audio run the following command to list all available video formats.
youtube-dl -F <video-URL>
Replace <video-URL> with the URL of the video that you want to download. Select a video format that says video only after it. In the following example I use the format code 160 which downloads mp4 video only, no audio.
youtube-dl -f 160 <video-URL>
Format code 160 is a low quality video, but there are usually several higher quality formats available for YouTube videos.
karel
  • 122,292
  • 133
  • 301
  • 332
The level of quality has been covered in the question linked; however, I do not believe that this is entirely duplicate, as the other question does not cover downloading without sound.
There are plenty of online tools which will allow you to do such tasks, such as savefrom; just paste the link to the youtube video and select one of the options with the red audio symbol in the dropdown next to download. You should be set to go.
anonymous2
  • 4,325
