What's the default credentials of Ubuntu 18.04 OVA (https://cloud-images.ubuntu.com/releases/18.04/release/ubuntu-18.04-server-cloudimg-amd64.ova)
you can create a new user or change passwd in grub Recovery Mode.
- holding - shiftkey for grub menu when booting virtualbox vm
- select Advanced -> recovery mode, then select root and press - enter
- passwdor add user:- adduser <username> usermod -aG sudo <username>
    - 91
The default user is ubuntu. Password for this user must be specified while deploying process.
For example for VMware player deployment process:
Setting password for a default user
    - 141
Ubuntu cloud images require cloud-init functionality to create loginable users (and whatever else needs to be done on boot). it sounds like vmware abstracts cloud-init away, and wraps it in vmware a "set user password" gui function, for ease of end-user. i have not tried specifing cloud-init, other than ec2, but sounds like cloud-init user solution would resolve this issue, for any virtualization that supports cloud-init (vmware, openstack, etc)
    - 111
- 1
- 1
- 5
If you came here after a very long search trying to get Ubuntu cloud image working on Virt-manager, because you cant login see here. It includes how to specify the password which is generated by cloud-init: What are the different versions available as Ubuntu cloud-images?
    - 850
