edit your .bashrc with the following :
gedit .bashrc
the line 2 export LD_LIBRARY_PATH=/usr/local/cuda-9.0/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}} looks like it is wrong.
if you wish to use this line you'll need to correct the shell syntax error. (if you cannot fix the syntax error on your own you can add lines 1-5 of your .bashrc to your original question).
If you cannot see why it is there or do no remember installing CUDA, you can simply remove the line.
save the file and run :
source .bashrc
this will fix it.
the messages you were getting were quite explicit, they are telling you what file has an error and where.
the reason why this is happening everytime you open a new terminal window/tab is because the .bashrc file, located in your home folder, is the "settings for this session's bash" file.
It is what bash loads as it's current configuration when you open a terminal. (files that start with a "." are hidden files. When in a folder, if you want to enable viewing hidden files, press CtrlH, the same combination will hide them again)
