I have a fresh installation of Ubuntu 18.04-x64.
In the terminal I enter the command:
sudo apt update
And I get the following error:
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
When I run sudo apt update again, the command runs successfully and I get:
Reading package lists... Done
Building dependency tree
103 packages can be upgraded. Run 'apt list --upgradable' to see them.
This behaviour is consistent. I have a VM snapshot of the fresh Ubuntu installation and everytime the first sudo apt update fails with this error and the second sudo apt update completes successfully.
EDIT: Should have mentioned that the sudo apt update command lies inside a script. Running the script with sudo privileges seems to have fixed the problem.
That issue is happening because the system identifies the fact the lock file is being used by another process. You can identify the process and kill it by
$ps aux | grep -i apt
$sudo kill -9 <pid>
If something happened during an apt-get process, like a system shutdown, then there will be no process having the file locked, by the problem will still be there. In that case you can reconfigure the necessary files, as follows:
$sudo rm /var/lib/apt/lists/lock
$sudo rm /var/cache/apt/archives/lock
$sudo rm /var/lib/dpkg/lock
$sudo dpkg --configure -a
Sarriman
  • 316
