I have a few videos i just want to add a fade to black effect or dissolve transition at the last 2 seconds with Kdenlive. My problem is that the output file is much larger than the original video. How do I keep the output video the same size and quality as the video I'm editing? And do I have to render the whole video if I'm only editing a few seconds or there's a faster way?
well if you never specify anything it never alters anything. This applies to any video editing software.
Wrong approach to making a video editing project start to finish :
- go to "file" -> "new project" specifing color, resolution and so on...
- we can stop here step one was already wrong (IMO)....
Correct approach (IMO) :
- (record the source material in the format you want, codec can be anything .mkv, .flv, .mp4 (preferably not .avi))
- Open the editing software and close the "new project" window that opens, if any.
- drag and drop video file in the editing app's project's "media library" section (not the timeline).
- then drag and drop video from the media file project library to the timeline. (the timeline de-facto inherit's that file's properties and won't be altered by further file drops to it even if the format is different, the first drop defines the project).
- edit
- on render don't add any resolution options, simply choose container (again .mkv and .flv is fine but prefer .mp4), encoding (here the choice is simple : hardware or software h264 but feel free to choose another encoding if you really want to.), the quality level and the filename).
(if you don't have a recording of your desired resolution to start with you can grab a sample off of youtube with a youtube downloader website and use that as a "timeline initilizer", once the timeline is set to that resolution and you've added one of your own files, you can remove it from the timeline).
this works for me in Kdenlive, Davinci Resolve and Premiere (on windows)
in editing I find the K.I.S.S. principles make you win out in time and results. And this approach is really as simple as it gets.
It's also fine to scale down, ...say you have some 2K/4K footage to mix with 1080p, then just add the 1080 bit to the timeline first (even if you're going to edit it last).
From there on the whole project is 1080p, then when you drag your 2k/4k footage to the timeline you'll find it overflows outside of the zone, you'll have to scale (and maybe crop) it and then the rest of the steps remain the same, at render you won't have to specify a resolution and the file you'll get will be a 1080p.
(also always select a small bit to render and render that first to test it before wasting several hours of rendering the whole project for something that isn't outputting the resolution/quality/sound/ect.. you want)
as for if you need to go through the hassle of rendering just for a small fade to black I think the answer is yes, until youtube finishes their new beta online editor and adds this sort of functionality. at that point you can offload menial render tasks to youtube.
- 3,346
Actually, you should just experiment with the quality slider, because it affects the cbr = %quality in your rendering profile (if it has this parameter), and moving it to the maximum will lead to unreasonably huge bitrates if your source files are not in the best quality.
For example, if you download a 720p video from youtube with the help of savefrom.net, you'll get it with a bitrate somewhere about 700-800 kbit/s and 24 fps.
Let's render it with the 'MP4-H264/AAC' profile from the 'Generic' section. So the final 720p 24 fps output if you move your quality slider to its maximum will have a bitrate about 4-5 Mbit/s which is >4 times more than it was in sources. But if you then move your slider to the middle, the output will have a bitrate about 1-1.5 Mbit/s which is much closer to the source, but won't lead to the losses in your quality.
And also, if you don't want to remember which position of the slider is for what then you can make your own rendering profiles and set constant CBR values for each (and also you can control your audio bitrate with ab=<your_value_in_kbit/s> in case if there are no high-quality video clips, but the sound was recorded in the studio [idk, maybe you're a beginner musician :D])
So what I wanted to say - try to control your video and audio bitrates based on the quality of your source files, because Kdenlive won't do this itself)
About the CBR you can read in FFmpeg's documentation, but if I'm right, it takes values from 0 to 51, where 0 is the best possible quality and 51 is the worst. Default is 23, but for the described case setting CBR to 30-33 won't make a huge difference but will save you some disk space :)
- 11
