I need to install WoeUSB to create a USB stick to install Windows, so I added the repository using:
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt update
and everything is fine until this point.
when i run sudo apt install woeusb I got this error:
Reading package lists... Done
Building dependency tree
woeusb : Depends: p7zip-full but it is not installable
Depends: libwxbase3.0-0v5 (>= 3.0.4+dfsg) but it is not installable
Depends: libwxgtk3.0-0v5 (>= 3.0.4+dfsg) but it is not installable
I honestly don't know what to do, i looked online and found nothing, can you help me?
