I have Intel NUC with Ubuntu 18.04 which operates as server the most time. Sometimes SSH is not enough and I need to control it using Team Viewer. This is why I installed and set up xserver-xorg-video-dummy because Team Viewer requires some display. Everything is working fine but when I want to connect physical display (to control server without network) dummy display does not allow to use physical display and monitor is saying there is no signal. Is there a way to configure Ubuntu to use both displays physical and dummy but to make physical display the most wanted? I mean when I connect it Ubuntu uses it, when disconnect Ubuntu switches to dummy.
My working config for dummy /etc/X11/xorg.conf is the following:
# This xorg configuration file is meant to be used
# to start a dummy X11 server.
# For details, please see:
# https://www.xpra.org/xorg.conf
# Here we setup a Virtual Display of 1920x1080 pixels
Section "Device"
    Identifier "Configured Video Device"
    Driver "dummy"
    VideoRam 256000
EndSection
Section "Monitor"
    Identifier "Configured Monitor"
    HorizSync 5.0 - 1000.0
    VertRefresh 5.0 - 200.0
EndSection
Section "Screen"
    Identifier "Default Screen"
    Monitor "Configured Monitor"
    Device "Configured Video Device"
    DefaultDepth 24
    SubSection "Display"
        Depth 24
        Modes "1920x1080" "1280x720"
    EndSubSection
EndSection
