This is how I did with Portecle version 1.11 and Ubuntu 18.04:
Download and unpack
Download the zip from the Sourceforge Portecle page.
Unpack the contents of a zip file on desired location, I prefer opt:
unzip portecle-1.11.zip
sudo mv portecle-1.11 /opt/
sudo ln -s /opt/portecle-1.11 /opt/portecle
Make it executable
To run .jar file easily you need, besides the Java runtime, the jarwrapper package which can be installed like this:
sudo apt-get install jarwrapper
Set the permission to execute the jar file:
chmod +x /opt/portecle/portecle.jar
For easy access, add it to PATH. If you don't have a ~/bin folder create it like this:
mkdir ~/bin
nano ~/.bashrc
Add a line last in the .bashrc:
export PATH=$PATH:~/bin
Re-read the file with:
source ~/.bashrc
(The idea of this ~/bin thing I borrowed from the How can I create a custom terminal command?)
Create a link to portecle in the folder:
ln -s /opt/portecle/portecle.jar ~/bin/portecle
If done correctly, you can start it from a terminal simply with:
portecle
Add to dash and launcher
To make Portecle searchable in the dash, link the icon and .desktop file to your profile:
ln -s /opt/portecle/icons/svg/portecle.svg ~/.local/share/icons/portecle.svg
ln -s /opt/portecle/net.sf.portecle.desktop ~/.local/share/applications/portecle.desktop
When started, you can right-click on its icon in the Ubuntu left panel (Launcher) and choose "Add to Favourites"/"Lock to Launcher" (depending on version).
