I have a Rubik's Futuro Cube and would like to use the desktop suite for customisation and the like.
I have previously had the program and want to install it on my new machine which is running Ubuntu 18.04.
Is there a way I can match the old dependencies to run it?
The download link is here (Completely virus free, taken directly from the website.).
And here is the full downloads page.
Install a Ubuntu Trusty for the next steps, or read my second answer to visualize a Trusty in Ubuntu Bionic or Debian Strech with LXC (Linux Container).
  • Prepare a Workspace. mkdir -p ~/work/rubiks/; cd ~/work/rubiks/
  • Download the file. wget http://isle.princip.cz/download/futurocube/sdk_suite/rubiks-futuro-cube.SC1.8.tgz
  • Extract the file. tar xfvz rubiks-futuro-cube.SC1.8.tgz
  • Go to the folder. cd rubiks-futuro-cube
  • Read the Documentation. vim INSTALL.txt
  • Do the steps:
    1. Install dependencies sudo apt install python ipython python-imaging python-serial python-wxgtk2.8
    2. Install 64bit compatibility sudo apt install ia32-libs (from INSTALL.txt, not longer needed)
    3. change the udev rule
    4. Add your user to the dialout group. sudo adduser $USER dialout
    5. Launch the program ./rubiks-futuro-cube
LupusE
  • 424
To be honest, it is a little more tricky, than I thought. But as I have a similar problem on my own, I've just created a solution that works for you, too (tested). Very helpful to understand all commands is this Blog article: https://blog.simos.info/how-to-easily-run-graphics-accelerated-gui-apps-in-lxd-containers-on-your-ubuntu-desktop/
  • Install snap ans LXD (Linux Container)
    1. # apt install snapd
    2. # apt purge lxd; snap install lxd
    3. # lxc init (In Debian Stretch I need to add /snap/bin/ to $PATH for root manually)
    4. Add pool as dir, no for IPv6 if not needed
    5. $ echo "root:$UID:1" | sudo tee -a /etc/subuid /etc/subgid
    6. $ lxc profile create gui
    7. $ wget [....]lxdguiprofile.txt see https://blog.simos.info/how-to-easily-run-graphics-accelerated-gui-apps-in-lxd-containers-on-your-ubuntu-desktop/ for details
    8. $ cat lxdguiprofile.txt | lxc profile edit gui
  • Setup VM
    1. # adduser [user] lxd (new login needed, see id if you are already joined the group, than /snap/bin should also be available in $PATH)
    2. $ lxc launch --profile default --profile gui ubuntu:trusty rubiks
    3. $ lxc exec rubiks -- sudo --user ubuntu --login
  • Finally use the commands from my fist answer in the VM
    1. $ sudo apt install python ipython python-imaging python-serial python-wxgtk2.8
    2. $ wget http://isle.princip.cz/download/futurocube/sdk_suite/rubiks-futuro-cube.SC1.8.tgz
    3. $ tar xfvz rubiks-futuro-cube.SC1.8.tgz
    4. $ cd rubiks-futuro-cube
    5. $ ./rubiks-futuro-cube
I've got no cube here, but I'm seeing your application.
If you're done, cleanup the playground (or stop here and keep it as long as you need).
  • Clean up
    1. close the application
    2. $ exit -> goes back to the physical system
    3. $ lxc stop rubiks
    4. $ lxc delete rubiks
LupusE
  • 424
