I've recently bought a new laptop that came with 250 GB SSD. I added 500 GB SSD as well. I've already installed ubuntu 18.04 in the 250 GB SSD. Also I'm thinking of installing Windows on the 500 GB drive much later (for games).
My questions are: 1) Should I opt for LVM management by re-installing ubuntu? I've heard how good it really is. I've heard it makes it into one drive - but SSDs don't work when they're near full. So will LVM just take care of things when one of the drive (say 250 GB SSD) gets nearly full?
2) Or, should I format the 500 GB with ext4, and encrypt it, and use it like an external harddisk? (Or is there any other alternatives?)
3) Is there any workaround to use Dropbox on an encrypted ext4 system? (I forgot to encrypt my ubuntu when installing; which I'm going to encrypt it soon) Thanks in advance.
May
  • 127
To LVM or not?
LVM for Spanning SSDs
LVM can be used for many different purposes. One of them is encryption, another is disk spanning, one can use both as well. Your first question is about disk spanning.
The default way disk spanning works will fill up one disk and then start putting files in the next one. However, this default behavior can be changed, and you can set it up to put the data (not necessarily files) evenly between the two disks.
One issue with disk spanning is you have no control where the data goes. For example, lets say you have a 5MB powerpoint file. Half of that file may be in one drive, and the rest in the other. This will speedup saving and loading the file. On the other hand, if one of the SSD fails, your data is toast. This is true not only for one file but for all the data in the LVM partition as a whole. Say you create a single 750 GB partition spanning the 250 GB SSD and the 500 GB SSD using LVM. One of the SSDs fails. You will have half a partition. There is no way to recover any data from half a partition in the working SSD.
You may want to create a large single partition spanning two SSDs if you need to work with a single 600GB file that won't fit in either of the SSDs.
See LVM - how is data allocated between disk for more information.
LVM for Encrypting Partitions
The LUKs encryption method will automatically create a LVM layer between the physical partition and the encryption layer.
It depends on what kind of data you will put in that SSD. If it is game saves and Lady Gaga songs, I would not bother with encryption. If it is your tax returns, and bank balance, I would encrypt the partition.
I understand the use the second SSD as an "external" disk to mean that the encrypted partition will not be mounted when the laptop boots. This means that you will not be asked for the encryption passphrase when the laptop boots. If and when you need to access this encrypted partition, you will enter the passphrase and mount the partition.
If you set it up this way, the data in the encrypted partition remains protected even when the laptop is on, as long as the partition is not mounted.
Other Alternatives
These alternatives are not about encryption, but mounting the second SSD. I assume you want to format the second SSD as a single partition. You can use encrypted partitions for these if you need it.
If you use encrypted partitions in the following alternatives, the encryption will only protect your data as long as the laptop is off. That is, if your laptop is off and a thief runs away with it, your data will be protected. However, if you are logged on and a thief gets your laptop, then there is no protection, as you have already unlocked the encrypted partition when the laptop booted.
/home in the second SSD
In Ubuntu (Linux in general) a partition is mounted as a folder. This means you can setup your 500 GB SSD as a (encrypted or not) single partition and mount it as the /home folder. If you do this, all your personal data, documents, music, videos, etc. will be in the 500 GB SSD.
If you have other users for this laptop, putting the whole /home folder in a separate partition (in the second SSD) and encrypting that partition means all the data for all the other users will be protected by encryption.
You don't have to put the whole /home folder in the second SSD. You can mount a partition in the second SSD as any sub-folder within the /home folder. Here are some examples:
If you are a music buff, you can dedicate the whole 500 GB SSD to music by creating a single ext4 partition and mounting that partition as /home/$USER/Music (where $USER is your username).
If you are a musician and want to protect your music from laptop thieves, you can LUKs encrypt this partition.
If you are a photographer, you can dedicate the whole 500 GB SSD to photos by creating a single ext4 partition and mounting that partition as /home/$USER/Pictures.
As a professional photographer you may want to protect your photographs from laptop thieves. You can LUKs encrypt this partition.
If you are a Youtuber, you can dedicate the whole 500 GB SSD to videos by creating a single ext4 partition and mounting that partition as /home/$USER/Videos.
As a professional vlogger you may want to protect your videos from laptop thieves. You can LUKs encrypt this partition.
Yes there is!
You will need to encrypt at the partition level (not at the folder level). In other words, it depends on what kind of encryption method you use. In the default Ubuntu installation, /home is a folder. The option to encrypt the home folder during installation uses ecryptfs a folder level encryption method. This does not work with Dropbox any more.
If you use a whole partition mounted as /home, then you can encrypt that partition using LUKs, which uses LVM as an underlying layer.
The /home partition can reside in either the first or the second SSD. However, since this is a partition level encryption, and Ubuntu needs to make sure the /home folder (which is a partition) is accessible during boot, you (and all other users) will be asked to enter the encryption passphrase when the system boots. If you forget the passphrase, your system will not boot. Moreover, you will not be able to get to your files, music, etc.
If your /home folder is not a separate partition, as it should be with a default installation, you can move /home to a new partition and at the same time encrypt that partition.
The process of creating the new /home encrypted partition and copying all your files is described in Ecrypfts to LUKS on ext4 partition
Hope his helps
user68186
  • 37,461
there's a lot to unpack here but first off (I've used my own numbering, these actually are separate ideas-questions-answers instead of one number spilling over into the next and vice-versa like you did) :
1.)
no, do not encrypt. you're not a spy and fixing your encrypted install is a nightmare that isn't worth the hassle.
2.)
if you're going to be putting each system on a separate drive there are two ways to approach this (neither of which require LVM since separate drives):
A: first make sure the drive you want to install windows to is first in the boot priority in BIOS (and ideally in first drive slot), install windows on top of ubuntu (delete it completely) then start powershell in windows with admin privileges and type powercfg -h off then use system settings to do a reboot to your ubuntu usb install key. I know this might be a hassle but in order for windows not to put it's EFI boot onto EVERY SINGLE DRIVE (thusly destroying grub) it is of capital importance Windows be first to be installed.
B: remove all drives, plug in first SSD nothing else, boot to windows installer, install windows, remove all drives, plug in second SSD boot to ubuntu installer, install ubuntu, use the BIOS to switch from one to the other. both oeses don't mess witch each other's SSD's MBR and aren't aware of one another even though they can mount each other's SSD. (well... ubuntu can)
3.)
I'm not sure this is evident enough but in the current climate, there's not all that many games not ported to linux or not playable with only as bad as a 10% drop in performance from windows using proton, wine or other. That being said a dual boot for games is still justifiable if you're going to be playing exclusively GTA4 (only runs on linux via hardware emulation) instead of say, Rise of the Tomb Raider, Dirt rally, Unreal Tournament 4, Cities Skylines and Rocket League (all of which are linux-native)
4.)
Dropbox is a really peculiar choice. I took a while to switch out of it because of how used to the interface I was but that was years ago. They only have the interface going for them then, the service itself was very lackluster, now with them not having especially led the cloud chariot, they must be decades behind.
Anyways no you cannot set up a Dropbox folder that is encrypted at a system level (that I know of, maybe there are some miracle-workers among us).
tatsu
  • 3,346
