I downloaded a fresh copy of ubuntu 18.04.2 installation disc (yes I did the md5 checksum of the image before making the bootable USB disk).
I then installed it on an old laptop.
I had an old installation of 14.04 on it, but I formatted the / partition (but not /home /opt/ partition), so there was no old libraries or binaries around, and install the new ubuntu 18.04 on the formatted / partition, but then mounted the old /home and /opt. Pretty standard stuff. When installing, I chose "download all updates" after installing, which I take is just doing apt-get update && apt-get dist-upgrade.
I then boot into the new installation. I did a
apt-get update
apt-get install build-essential
build-essential : Depends: gcc (>= 4:7.2) but it is not going to be installed
Depends: g++ (>= 4:7.2) but it is not going to be installed
This is a fresh installation and I could not install build essential!
aptitude install build-essential
throw up some none-sense errors like this
Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.2.0-1ubuntu2~18.04 is installed
Not to be daunted, I tried a simpler fare:
apt-get install gcc
Depends: gcc-7 (>= 7.3.0-12~) but it is not going to be
installed E: Unable to correct problems, you have held broken packages.
But of course, I have gcc-8 installed!
aptitude install gcc
libtsan0 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.2.0-1ubuntu2~18.04 is installed
liblsan0 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.2.0-1ubuntu2~18.04 is installed
libatomic1 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.2.0-1ubuntu2~18.04 is installed
I tried to install the basic numerical package lapack
aptitude install liblapack3
libquadmath0 : Depends: gcc-8-base (= 8-20180414-1ubuntu2) but 8.2.0-1ubuntu2~18.04 is installed
There must be something really broken in ubuntu's end.
My /etc/apt/sources.list is pristine, and has only these lines not
commented off:
deb http://archive.ubuntu.com/ubuntu bionic main restricted
deb http://archive.ubuntu.com/ubuntu bionic universe
deb http://archive.ubuntu.com/ubuntu bionic multiverse
deb http://archive.ubuntu.com/ubuntu bionic partner
I've been using Ubuntu as my primary os for over 14 years, since 5.04 days, but never seen anything like this before. I thought by doing a fresh installation (rather than upgrade) on a LTS version would be relatively safe...
Any help would be greatly appreciated by this very confused user.
