  1. I'm currently running the following PHP/Xdebug setup:
PHP 7.2.15-0ubuntu0.18.10.1 (cli) (built: Feb 8 2019 14:54:22) ( NTS ) Copyright (c) 1997-2018 The PHP Group Zend Engine v3.2.0, Copyright (c) 1998-2018 Zend Technologies with Zend OPcache v7.2.15-0ubuntu0.18.10.1, ... with Xdebug v2.6.0, Copyright (c) 2002-2018, by Derick Rethans
  1. Reading up on Installing PHPUnit, the docs state that --based on my installed version of PHP (7.2.15) -- I need to install PHPUnit 8.0. And the code coverage report feature for PHPUnit 8.0 requires the Xdebug (2.7.0 or later) and tokenizer extensions. Generating XML reports requires the xmlwriter extension.
  2. But, I'm running Xdebug v2.6.0. So I ran sudo apt-get install php-xdebug to try to update Xdebug and saw this...
Reading package lists... Done Building dependency tree
Reading state information... Done php-xdebug is already the newest version (2.6.0-0ubuntu1). 0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
So... I cant upgrade? ...now what?
sleeper
  • 145
Follow these steps :
sudo apt install software-properties-common
sudo add-apt-repository ppa:ondrej/php
sudo apt update
sudo apt-cache policy php-xdebug
Then you can choose what version you want to install.
sudo apt install php-xdebug=2.7... (copy whole version number)
And to confirm the right version was installed php -v.
Anyway, if you encounter any issues, copy the output here and I'll try to help you out.
Takman
  • 151
