I recently installed VS code and I cannot download the g++ compiler. I type sudo apt install g++ and it returns
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
binutils binutils-common binutils-x86-64-linux-gnu cpp cpp-7 g++-7 gcc gcc-7 gcc-7-base libasan4 libatomic1 libbinutils libc-dev-bin libc6-dev libcc1-0 libcilkrts5
libgcc-7-dev libgomp1 libisl19 libitm1 liblsan0 libmpc3 libmpx2 libquadmath0 libstdc++-7-dev libtsan0 libubsan0 linux-libc-dev manpages-dev
Suggested packages:
binutils-doc cpp-doc gcc-7-locales g++-multilib g++-7-multilib gcc-7-doc libstdc++6-7-dbg gcc-multilib make autoconf automake libtool flex bison gdb gcc-doc
gcc-7-multilib libgcc1-dbg libgomp1-dbg libitm1-dbg libatomic1-dbg libasan4-dbg liblsan0-dbg libtsan0-dbg libubsan0-dbg libcilkrts5-dbg libmpx2-dbg libquadmath0-dbg
glibc-doc libstdc++-7-doc
The following NEW packages will be installed:
binutils binutils-common binutils-x86-64-linux-gnu cpp cpp-7 g++ g++-7 gcc gcc-7 gcc-7-base libasan4 libatomic1 libbinutils libc-dev-bin libc6-dev libcc1-0
libcilkrts5 libgcc-7-dev libgomp1 libisl19 libitm1 liblsan0 libmpc3 libmpx2 libquadmath0 libstdc++-7-dev libtsan0 libubsan0 linux-libc-dev manpages-dev
0 upgraded, 30 newly installed, 0 to remove and 0 not upgraded.
Need to get 987 kB/35.9 MB of archives.
After this operation, 155 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Ign:1 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 linux-libc-dev amd64 4.15.0-29.31
Err:1 http://security.ubuntu.com/ubuntu bionic-updates/main amd64 linux-libc-dev amd64 4.15.0-29.31
404 Not Found [IP: 91.189.88.161 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/l/linux/linux-libc-dev_4.15.0-29.31_amd64.deb 404 Not Found [IP: 91.189.88.161 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I have tried running apt-get update and tried deleting the sudo g++ file and reinstalling it, nothing seems to work.
