i have a wordpress site that uses Duplicator plugin. In order for this plugin to work it needs php7.0-zip
[root@server1:~# apt-get -y install php7.0-zip
Reading package lists... Done
Building dependency tree
 php7.0-zip : Depends: php7.0-common (= 7.0.33-0+deb9u3) but 7.0.33-5+0~20190309015553.9+stretch~1.gbp4c6517 is to be installed
Thomas Ward
  • 78,878
adam
  • 303
Since php7.0-common (= 7.0.33-0+deb9u3) is a dependency, as shown by your console, I suggest you install it first before installing php7.0-zip. You can find the Debian package here.
Also, the best approach to get these packages installed is to use package managers such as aptitude or synaptic. You can install any of them and use as follows:
-- aptitude:
sudo apt-get update
sudo apt-get install aptitude
sudo aptitude update
sudo aptitude install php7.0-common php7.0-zip -y
-- synaptic:
sudo apt-get update
sudo apt-get install synaptic
Synaptic has a GUI you can use and in case you can't launch it after installing, see this.
I hope this answer helps you out!
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
Please try again with the tool "aptitude". It may suggest to also update packages that you did not explicitly list to update, which would be in conflict with the versions you requested. You can then ask for different solutions to be offered wrt what other package should also get to later versions:
aptitude install php7.0-zip
On my system I have php7.3 and php7.0 available. Maybe you already mixed this up? You may alternatively want to try installing the package php-zip, so you get whatever is current for the distribution you are working with.
smoe
  • 455
