Xubuntu 18.10
So the other day I went to run TeamViewer and found it was gone. So I tried to re-install it and this happens:
$ sudo apt install teamviewer
Reading package lists... Done
Building dependency tree
 teamviewer : Depends: libqt5qml5 (>= 5.5) but it is not going to be installed or
                       qt56-teamviewer but it is not going to be installed
              Depends: libqt5quick5 (>= 5.5) but it is not going to be installed or
              Depends: libqt5webkit5 (>= 5.5) but it is not going to be installed or
              Depends: qml-module-qtquick2 (>= 5.5) but it is not going to be installed or
              Depends: qml-module-qtquick-controls (>= 5.5) but it is not going to be installed or
              Depends: qml-module-qtquick-dialogs (>= 5.5) but it is not going to be installed or
              Depends: qml-module-qtquick-window2 (>= 5.5) but it is not going to be installed or
              Depends: qml-module-qtquick-layouts (>= 5.5) but it is not going to be installed or
I've tried a few things:
$ sudo apt-get install -f
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
I've also tried Synaptic to install qt56-teamviewer, but that fails too and just says it's "broken".
I suspect a non-standard PPA repository, but any useful way to determine which one so I just fix this problem without causing other problems (such as blowing away the entire sources.list and replacing with default)? I noticed a lot of the sources have bionic in them even though I'm on cosmic. Should I change all references to bionic to cosmic instead?
-----------edits below---------
    $ apt-cache policy qt56-teamviewer libqt5qml5 teamviewer
qt56-teamviewer:
  Installed: (none)
  Candidate: 5.6.3.0
  Version table:
     5.6.3.0 500
        500 http://linux.teamviewer.com/deb stable/main amd64 Packages
libqt5qml5:
  Installed: (none)
  Candidate: 5.9.5-0ubuntu1.1
  Version table:
     5.9.5-0ubuntu1.1 500
        500 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
     5.9.5-0ubuntu1 500
        500 http://us.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
teamviewer:
  Installed: (none)
  Candidate: 14.2.2558
  Version table:
     14.2.2558 500
     14.1.18533 500
        100 /var/lib/dpkg/status
     14.1.9025 500
     14.1.3399 500
     14.0.14470 500
     13.2.26559 500
     13.2.13582 500
sremick
