You can do this with rename using bash’s globstar option:
shopt -s globstar
rename -n 's/.*\//$&JPEG\//' **/*.jpeg
rename -n 's/.*\//$&TIF\//' **/*.tif
The -n option lets it just output what it would do, remove it to actually perform the moving. What happens here is that rename goes over each e.g. .jpeg file in any subdirectory thanks to ** matching any number of subdirectories. It substitutes its path (everything until the last /) with itself ($&) followed by JPEG/, effectively moving the file to this directory.
If your list of arguments is too long the commands above will throw an error. Use this approach to work around the shell’s ARG_MAX limit:
printf '%s\0' **/*.jpeg | xargs -0 rename -n 's/.*\//$&JPEG\//'
printf '%s\0' **/*.tif | xargs -0 rename -n 's/.*\//$&TIF\//'
This uses the shell builtin printf to build a zero-delimited argument list which is piped to xargs which calls rename with the maximum number of arguments.
Example run
$ tree
├── subdirectory-A
│ ├── 1.tif
│ ├── 2.tif
│ ├── JPEG
│ └── TIF
└── subdirectory-B
├── 1.tif
├── 2.tif
├── JPEG
└── TIF
$ shopt -s globstar
$ rename -n 's/.*\//$&JPEG\//' **/*.jpeg
rename(subdirectory-A/1.jpeg, subdirectory-A/JPEG/1.jpeg)
rename(subdirectory-A/2.jpeg, subdirectory-A/JPEG/2.jpeg)
rename(subdirectory-B/1.jpeg, subdirectory-B/JPEG/1.jpeg)
rename(subdirectory-B/2.jpeg, subdirectory-B/JPEG/2.jpeg)
$ rename 's/.*\//$&JPEG\//' **/*.jpeg
$ printf '%s\0' **/*.tif | xargs -0 rename 's/.*\//$&TIF\//'
$ tree
├── subdirectory-A
│ ├── JPEG
│ └── TIF
│ ├── 1.tif
│ └── 2.tif
└── subdirectory-B
├── JPEG
└── TIF
├── 1.tif
└── 2.tif
