I recently installed Ubuntu 16.04 on my Lenovo Twist, however, the touchpad does not work when I first boot the computer from shutdown. After I restart the computer, the touchpad works. How can I get the touchpad to work when I boot Ubuntu? Do I need to configure something in the Bios?
For clarification, when I run xinput on startup/boot, I do not see the SynPS/2 Synaptics TouchPad and the TPPS/2 IBM TrackPoint. Rather, when I restart my computer (not from shutdown), xinput shows both.
I have uninstalled the synaptics driver, which resulted in no touchpad behavior even after a restart. So I then reinstalled it which then produced the above behavior again.
I changed the grub file multiple times under the line GRUB_CMDLINE_LINUX_DEFAULT= to the following with no fix:
- quiet splash i8042.nopnp
- i8042.reset quiet splash
- quiet splash i8042.kbdreset=1 i8042.nomux=1 i8042.reset
- quiet splash i8042.reset i8042.nomux=1
- quiet splash i8042.nomux i8042.reset=1
- quiet splash i8042.reset i8042.nomux i8042.nopnp i8042.noloop
- i8042.nomux=1 locale=fr_FR i8042.reset
I have blacklisted i2c_hid and commented out i2c_i801 from /etc/modprobe.d/blacklist.conf with no results.
I followed the instructions from the following links to no avail:
- Dell Inspiron 3551 Unresponsive Touchpad
- Touchpad not working after suspend Ubuntu 16.04
- Touchpad under 16.04 not working
- Touchpad doesn't work on startup but does on reboot
- Touchpad/Keyboard problems
- Touchpad is not recognized
Any suggestions would be greatly appreciated.
