I've uninstall flatpak with:
sudo apt remove flatpak
but I'm getting a:
flatpak: command not found
everytime I start the terminal, I checked the .profile and the .bashrc to see where that command could be invoked but found nothing. I even used fzf to search and remove any flatpak things left behind and checked this question and remove the relevant files but I'm still getting that error when lunching the terminal. Any help is appreciated!
bpinaya
  • 395
  • 13
It seems this file in:
/etc/profile.d/flatpak.sh
was causing the issues. After deleting everything worked ok.
bpinaya
  • 395
  • 13
As you pointed in previous answer, the problem comes from /etc/profile.d/flatpak.sh file.
To avoid removing it by hand (I don't like this on system files) you can use apt:
sudo apt purge flatpak
Mathieu
  • 361
