I have this warning using apt:
$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
  python3-protobuf
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
To fix it, I'm trying:
$ sudo apt-get install python3-protobuf
 python3-protobuf : Depends: libprotobuf15 but it is not going to be installed
So it asks to install libprotobuf15. I already have libprotobuf10.
When I try to install libprotobuf15, I see that lots of packages that look like system ones are going to be removed:
$ sudo apt-get install libprotobuf15
The following packages were automatically installed and are no longer required:
  bamfdaemon compiz-core compiz-plugins-default gazebo9-common gir1.2-accounts-1.0 gir1.2-clutter-1.0 gir1.2-cogl-1.0 gir1.2-coglpango-1.0 gir1.2-gdata-0.0
  gir1.2-signon-1.0 gtk3-nocsd hud libavdevice57 libbullet2.87 libccd2 libcolumbus1-common libcolumbus1v5 libdbusmenu-qt5-2 libdecoration0 libframe6 libgeis1
  libglewmx1.13 libgrail6 libgsettings-qt1 libgtk3-nocsd0 libignition-common libignition-fuel-tools1-1 libignition-math4 libmetacity1 libnux-4.0-0 libnux-4.0-common
  libqtpropertybrowser4 libsdformat6 libsignon-glib1 libsimbody3.5v5 libspnav0 libtar0 libunity-core-6.0-9 libunity-misc4 libzeitgeist-1.0-1 metacity-common
  nux-tools python3-blinker python3-feedparser python3-jwt python3-oauthlib sdformat-sdf session-shortcuts unity-asset-pool unity-lens-applications unity-lens-files
  unity-lens-music unity-lens-photos unity-lens-video unity-schemas unity-scope-calculator unity-scope-chromiumbookmarks unity-scope-colourlovers
  unity-scope-devhelp unity-scope-firefoxbookmarks unity-scope-home unity-scope-manpages unity-scope-openclipart unity-scope-texdoc unity-scope-tomboy
  unity-scope-video-remote unity-scope-virtualbox unity-scope-yelp unity-scope-zotero unity-scopes-master-default unity-scopes-runner
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  python3-protobuf
The following packages will be REMOVED:
  compiz compiz-gnome evolution-data-server gazebo9 gazebo9-plugin-base gdm3 gnome-shell gnome-shell-extension-dash-to-panel gnome-shell-extensions gnome-todo
  libcompizconfig0 libebook-1.2-19 libebook-contacts-1.2-2 libedata-book-1.2-25 libgazebo9 libignition-msgs libignition-transport4 libphonenumber7 libprotobuf10
  libprotoc10 ubuntu-desktop ubuntu-session ubuntu-unity-desktop unity unity-session unity-tweak-tool
The following NEW packages will be installed:
  libprotobuf15
The following packages will be upgraded:
  python3-protobuf
1 upgraded, 1 newly installed, 26 to remove and 0 not upgraded.
Need to get 1'019 kB of archives.
After this operation, 73.8 MB disk space will be freed.
Do you want to continue? [Y/n]
Is it safe to proceed, especially regarding the 'ubuntu' and 'unity' packages (I installed 'unity' back just after installing the 18.04 version because I'm on a laptop and I care about vertical space)?
Do you also encountered this?
s.k
  • 1,490
