-4
I have tried to excute sudo apt-get update command but it return below error:
E: Failed to fetch http://ppa.launchpad.net/upubuntu-com/web/ubuntu/dists/xenial/main/binary-amd64/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Please provide solution. as I am not able to install other packages due to the error.
Soren A
  • 7,191
Dev Ramesh
  • 93
The error tells that the repository doesn't exist (or that there is a spelling error in the url - ending up in the same not found situation). It doesn't stop you from upgrading your software or installing new. Just run sudo apt-get upgrade or sudo apt-get install <some package>.
To get rid of the error find and comment out (by adding a # in front of the line) the line in /etc/apt/sources.listor in one of the files (if any) in /etc/apt/sources.d
Soren A
  • 7,191
