I installed nvidia driver by:
$ sudo add-apt-repository ppa:graphics-drivers/ppa
$ sudo apt-get install nvidia-390
But it looks like the driver isn't running properly:
$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
I've checked the kernel module by lsmod | nvidia but failed to find it.
Here's the output for lshw and lspci, hoping it could help:
$ lspci
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06)
01:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] (rev a1)
$ lshw -C display        0s
WARNING: you should run this program as super-user.
  *-display UNCLAIMED
       description: 3D controller
       product: GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: bus_master cap_list
       configuration: latency=0
       resources: memory:f2000000-f2ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:6000(size=128)
  *-display
       description: VGA compatible controller
       product: 4th Gen Core Processor Integrated Graphics Controller
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 06
       width: 64 bits
       clock: 33MHz
       capabilities: vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:29 memory:f3000000-f33fffff memory:d0000000-dfffffff ioport:7000(size=64) memory:c0000-dffff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
Rebooting, disabling Secure Boot and prime-select nvidia all have no effect.
I'm using Ubuntu 18.04 with 4.18.0-16-generic. Thanks for your advices!
whuala
  • 153
I am not sure you found a solution but only Nvidia 304 works for older cards but installing 304 gives you dependency issues
So you follow the instructions on this AskUbuntu question Can't install Nvidia drivers on Ubuntu 18.04
and patch up the installer from Nvidia and run it. It worked for me.
pt123
  • 652
