I want to install the latest lts ubuntu on my desktop but keep getting a black screen after bootloader login . It works on dvi but not VGA . My main VGA monitor is Samsung s22c150 21.5inch HD and the dvi is only a 19inch LCD. Don't know the make as its over 6 years old.
My PC specs Ryan 5 1600x Drevo ssd 120gb R9 380x nitro 4gb Gigabyte ab350 Max bran 1000w psu Corsair h60 2tb segate I have tried using yumi to install ubuntu on a USB and the same with rufus
I downloaded it twice from ubuntu main site I have also tried f6 and tried all options and luck. I do remember it working on previous version but then I upgraded and black screen. I tried ubuntu 12.04 and the screen is being detected as a laptop screen in settings with no option to change the size and also the wifi wont connect really want to switch to ubuntu instead of windows
Irish guy
Try Alternate CD. It usually works. Installer uses better hardware detection than LiveCD, so after the textmode (Alt. CD) installation, the system usually works well.
If it does not, you can boot in safe mode and edit the configuration files manually (it'll be another question). Or there can be a workaround (for example, GPD Win + Lubuntu 18.04 requires a single closing/opening the lid after each reboot; the screen is black before you do it).
There are also some parameters you can tweak on the first LiveCD screen (sorry, I don't remember how to access them on UEFI boot). Maybe some of them can help with initial display mode.
NickDoom
  • 269
