I created extended partition for windows and now I want to convert this partition from MBR to GPT. How can I do this?
DonnaTelloo
  • 101
One of the main challenges that we face while converting MBR to GPT is that conversion is possible from MBR to GPT, only if there are no partitions or volumes present in the disk. So, before you start, ensure there are no partitions on your disk. If there are, follow these steps:
  • Create a complete Backup of your disk partitions and Data.
  • Right click on Start Menu >> Command Prompt (Admin) to open a command prompt with elevated privileges
  • On the prompt screen, type diskpart and hit the Enter key
  • Type list disk to obtain the list of disks
  • Note down the number/id of the disk you wish to convert into GPT. Once you have it, type the command: select disk <id>. Once, you hit the Enter key, you would receive a notification stating that your disk is now selected.
  • Finally, type in convert gpt to convert your disk into GPT
Once your disk is converted, you can recreate your partitions and restore the data.
Manu Mathur
  • 1,048
