I was using openSUSE and Manjaro before I start using Ubuntu (kubuntu). Now there's boot options such as windows boot manager, Manjaro, debian, etc. How can I delete those options from my Lenovo laptop bios boot menu?
Asked
Active
Viewed 2,868 times
Open your Ubuntu terminal using the key combination Alt + Ctrl + T and follow the below procedure:
- Paste the following command in terminal
sudo gedit /etc/default/grub. It will open a file named/boot/grub/grub.cfgfile Add
GRUB_DISABLE_OS_PROBER=trueat the bottom of this fileIt will prevent
Windowsbeing added to your grub menuNow to write the change, run the command:
sudo update-grubYou can then run
cat /boot/grub/grub.cfgto check that yourWindowsOS entry has disappeared.- Restart your device to check the same
Manu Mathur
- 1,048
I use "Grub Customizer" which is an easy to use GUI tool to remove or change your grub menu.
There's a whole tutorial on how to download and how to use it here - You really don't need to read it though.
Basically you just install it and choose which options you want from the GUI (it's very simple)
$ sudo add-apt-repository ppa:danielrichter2007/grub-customizer
$ sudo apt-get update
$ sudo apt-get install grub-customizer
mkkl
- 495
