I was trying to install a new package on 16.04 last night, but received an error indicating /boot was full. I've run into this before, and the solution was to purge files, so I decided to just purge one, apparently the wrong one.
(I saw vmlinuz-4.15.*-generic and vmlinuz-4.8.*-generic. I was late, so I deduced that 4.8 was old and should keep the 15s...)
Anyway, on reboot, I got file not found, you need to load the kernel first.
I found directions on recovering a deleted kernel, but I've confused myself. I have dual 3 drives, one with 12.04 (which is where I am know) and Windows (7? I don't actually use it), and then a second drive with 16.04, and a really old one with maybe Windows XP.
parted -l shows:
Model: ATA WDC WD1600JB-00G (scsi)
Disk /dev/sda: 160GB Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number  Start   End    Size   Type     File system  Flags
 1      32.3kB  160GB  160GB  primary  ntfs         boot
Model: ATA WDC WD1002FAEX-0 (scsi)
Disk /dev/sdb: 1000GB Sector size (logical/physical): 512B/512B
 1      1049kB  530GB   530GB   primary   ntfs            boot
 2      530GB   1000GB  470GB   extended
 5      530GB   996GB   466GB   logical   ext4
 6      996GB   1000GB  4293MB  logical   linux-swap(v1)
Model: ATA WDC WD1003FZEX-0 (scsi)
Disk /dev/sdc: 1000GB Sector size (logical/physical): 512B/4096B
 1      1049kB  8000MB  7999MB  primary   linux-swap(v1)
 2      8001MB  1000GB  992GB   extended
 5      8001MB  33.0GB  25.0GB  logical   ext4
 6      33.0GB  33.5GB  499MB   logical   ext4
 7      33.5GB  43.5GB  9999MB  logical   ext4
 8      43.5GB  53.5GB  9999MB  logical   ext4
 9      53.5GB  1000GB  947GB   logical   ext4
On boot, grub offers choices as being on sdb5. Sdb5 only list vmlinuz-3.*, so that would be the the install for 12.04. The files for 16.04 seem to be on sdc6. Edit: It looks like sdc5 may be the mount point for that drive, since the listing for that shows /root, /boot, /bin and so on.
So,after all that info dump, my question is:
Which partitions to I mount to what? /dev/sdb5 or /dev/sdc5 to /mnt and then /dev/sdc6 to /mnt/boot? or...? (And also, when I install the kernel, will it figure out I need 4.8, or will I need to specify it?)
Thanks.
