I tried uninstalling android studio and i am getting this and also many times before i have got this type of lines, but in my file system i have .android and .AndroidStudio folders and many more. How to remove android studio completely from my Ububtu system.
(base) TravelMate-P243:~$ sudo apt-get remove android-studio
Reading package lists... Done
Building dependency tree
Package 'android-studio' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 58 not upgraded.
P. L
sudo apt remove android-studio will remove the package with all of its included binaries and libraries from your system. It will also remove (or at least mark as unused and ready for removal) any packages that were installed as dependency of this one and which are not needed by anything else any more.
It may leave some system-wide configuration files behind though, which would help you to restore pretty much the same application state again when you reinstall the package later.
With sudo apt purge android-studio instead, the package manager will also purge all related system configuration files.
However, apt will never remove user data. If the application created any folders and files to store user configuration or anything else in your home directory, you have to delete those manually if you want. The package manager is not supposed to touch user homes.
For more information, check Why don't programs completely uninstall (remove all their files) when I remove them?
Byte Commander
  • 110,243
