I try to enable one finger scrolling in firefox ( it's more comfortable to scroll like that with a touchscreen). The default fedora version of firefox and chromium work like that.
I tried to launch firefox with the option MOZ_USE_XINPUT2=1 but it doesn't work.. Can you help me ??
Poumon
  • 111
I had similar issues with the HP Pavilion x360. I found that MOZ_USE_XINPUT2=1 only works in Wayland, not Xorg. Furthermore, to make it a permanent solution I needed to follow these steps:
  1. open about:config in firefox to set dom.w3c_touch_events.enabled=1 (default is 2).
  2. edit /etc/security/pam_env.conf and add MOZ_USE_XINPUT2 DEFAULT=1
  3. reboot and restart firefox
See https://askubuntu.com/a/994483/799524
I just might have the solution for you.
I was facing the exact same issue with Firefox where I could only scroll with two-fingers and single finger selected text.
After a lot of searching I found this Gentoo Wacom page mentioning that the Wacom driver has gesture emulation that causes a problem with Firefox and my Thinkpad X1 Yoga has a Wacom touchscreen.
The fix is to turn off the Wacom gesture setting by creating the following file:
/etc/X11/xorg.conf.d/50-wacom.conf
With this configuration:
Section "InputClass"
    Identifier "Wacom class"
    MatchProduct "Wacom|WACOM|Hanwang|PTK-540WL|ISDv4|ISD-V4|ISDV4"
    MatchDevicePath "/dev/input/event*"
    Driver "wacom"
    Option "Gesture" "off"
EndSection
Resart and enjoy :)
Cas
  • 8,707
found a solution based on the wacom config file Cas mentioned, whose solution ultimately didnt work for me on my yoga 7. however, based on this i found, in the KDE system control panel, under input devices the section graphic tablets. there is a register card touch with a checkbox enable gestures which is activated by default. after disabling it, gestures worked again in firefox. seems they enabled it from 21.10 to 22.04. and yes, as also mentioned by Cas, when this checkbox remains enabled, i have to scroll with two fingers in firefox. i didnt know that.
[checkbox][1] [1]: https://i.sstatic.net/9fpTP.png
