I have a server I prepped here in the office and got everything working.
I set up auto-login followed by an immediate lock-screen so that vino would start automatically after a reboot.
I took the rack out to an ISP to COLO the server, -without- a monitor/keyboard/mouse, and everything still works except vino does not start up now that it is headless. Auto-login is still working. w shows:
mylogin :0 :0 14:32 ?xdm? 41.02s 0.01s /usr/lib/gdm3/gdm-x-session --run-script env GNOME_SHELL_SESSION_MODE=ubu
But nothing in the listeners for vino-server. netstat -anp shows:
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 1496/mysqld
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 3314/apache2
tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 1309/systemd-resolv
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 6582/sshd
tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 2722/master
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 3314/apache2
tcp 0 0 127.0.0.1:9632 0.0.0.0:* LISTEN 1894/xinetd
I'd like to make it possible to turn vino-server on and off at will via the command line like we've done in the past with VNC server. My plan was to use ufw to firewall/un-firewall port 5900 as needed - so just getting vino-server running would solve my problem.
I tried running /usr/lib/vino/vino-server --display=:0 from a secure shell session, but it appears that only works from session with access to DBUS. - Any help is appreciated.
