When reading How do I restrict a specified SSH user to connect only from one IP or hostname? I came close to solving a problem I have with specific logins - but it does not cover my case.
I need to ensure that an ssh connection to my host coming from anything else than 192.168.10.0/24 is authenticated via a key. Connections from 192.168.10.0/24 can use both (or only password based if this is a problem).
The ssh_config man page mentions in the PATTERNS section that
the following entry (in
authorized_keys) could be used:from="!*.dialup.example.com,*.example.com"
This would allow for a solution exactly opposite to mine: that some sources are not allowed to use keys but I do not see how to turn it into my need.
How to force the use of ssh keys when the client does not connect from certain IPs?
