First of all, I'm completely new to this, been a Windows user for as long as I can remember and I've been thinking about dual booting Ubuntu with my Windows 10 for some time now.
I've run into one problem that I can't seem to fix, couldn't find a lot of similar problems on Google either.
I've tried creating a live USB on a 32gb memory device. I've tried etcher, rufus, even netbootin. The boot manager works fine, I boot into the screen where you can choose "Install Ubuntu or "Try Ubuntu Without Installing". I've tried pressing either one but I always get the same error, which is:
xhci_hcd 0000:02:00.0: Error while assigning device slot ID
xhci_hcd 0000:02:00.0: Max number of devices this xHCI host supports is 127
usb_usb1-port6: couldn't allocate usb_device
Can you guys help? I'm happy to provide all the information I can.
slava
  • 4,085
(it came with a search result, let's leave this for future use)
The problem is solved in my case with added irqpoll in file grub.cfg as kernel parameter.
If you have a USB-2 port, try to install it from there. After the installation, edit the grub.cfg file to add the irqpoll to the kernel parameter.
Probably it's better to append the irqpoll option to /etc/default/grub GRUB_CMDLINE_LINUX_DEFAULT value.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
krg
