Ever since I updated my laptop to Ubuntu 18.04 my bluetooth has not been working. When I try to open bluetooth in the system settings it takes a while to open and when I turn it on or off it keeps saying "Turn on to connect devices and receive file transfers".
I thought to fix this issue later but since I also noticed my battery drains insanely fast I wondered what that could be. Using the "top" or "htop" command in my terminal I saw the cause of this. The process "bluetoothd" is showing 100% CPU usage. I wonder what it's doing because it's unusable.
Now I really want to be able to use bluetooth again and I tried different ways to fix it, namely:
- adding "AutoEnable=true" in /etc/bluetooth/main.cfg
- sudo apt install bluez
- sudo service bluetooth stop/start/restart
- systemctl bluetooth stop/start
Probably some other stuff I can't remember. Anyway to stop my laptop from draining the battery I have to force the "bluetoothd" process to stop. Otherwise my laptop will be dead within one hour...
My bluetoothd version is 5.50, I thought I manually updated that too but I'm not sure.
I hope someone can help me with this issue.
EDIT: lspci -knn | grep Net -A3; lsusb
02:00.0 Network controller [0280]: Intel Corporation Wireless 7260 [8086:08b1] (rev 73)
Subsystem: Intel Corporation Dual Band Wireless-AC 7260 [8086:4070]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
Bus 001 Device 002: ID 8087:8000 Intel Corp.
Bus 003 Device 002: ID 0424:5534 Standard Microsystems Corp. Hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 003: ID 04f2:b3ed Chicony Electronics Co., Ltd
Bus 002 Device 004: ID 8087:07dc Intel Corp.
Bus 002 Device 002: ID 0424:2134 Standard Microsystems Corp. Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
EDIT2: dmesg | grep -i blue; uname -a; rfkill list
[ 25.918370] Bluetooth: Core ver 2.22
[ 25.918390] Bluetooth: HCI device and connection manager initialized
[ 25.918393] Bluetooth: HCI socket layer initialized
[ 25.918395] Bluetooth: L2CAP socket layer initialized
[ 25.918398] Bluetooth: SCO socket layer initialized
[ 26.426223] Bluetooth: hci0: read Intel version: 370710018002030d00
[ 26.474144] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.80.2.3.d.bseq
[ 26.613246] Bluetooth: hci0: Intel firmware patch completed and activated
[ 45.410462] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 45.410466] Bluetooth: BNEP filters: protocol multicast
[ 45.410472] Bluetooth: BNEP socket layer initialized
Linux HP 4.20.13-042013-generic #201902270533 SMP Wed Feb 27 10:35:20 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
EDIT3: systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; disabled; vendor preset: enabled)
Active: active (running) since Mon 2019-03-04 16:24:58 CET; 2s ago
Docs: man:bluetoothd(8)
Main PID: 25143 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 4915)
CGroup: /system.slice/bluetooth.service
└─25143 /usr/lib/bluetooth/bluetoothd
mrt 04 16:24:58 HP systemd[1]: Starting Bluetooth service...
mrt 04 16:24:58 HP bluetoothd[25143]: Bluetooth daemon 5.50
mrt 04 16:24:58 HP systemd[1]: Started Bluetooth service.
mrt 04 16:24:58 HP bluetoothd[25143]: Starting SDP server
mrt 04 16:24:58 HP bluetoothd[25143]: Bluetooth management interface 1.14 initialized
mrt 04 16:24:58 HP bluetoothd[25143]: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
mrt 04 16:24:58 HP bluetoothd[25143]: avrcp-controller: Protocol not supported (93)
mrt 04 16:24:58 HP bluetoothd[25143]: audio-avrcp-target: Protocol not supported (93)
