I want to free up some of the space in /boot but i am not able to do so.
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda1 474730 463590 0 100% /boot
I have tried sudo apt-get autoremove --purge but following error
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
linux-image-extra-4.4.0-137-generic : Depends: linux-image-4.4.0-137-generic but it is not installed
linux-image-extra-4.4.0-142-generic : Depends: linux-image-4.4.0-142-generic but it is not installed
linux-image-generic : Depends: linux-image-4.4.0-142-generic but it is not installed
Recommends: thermald but it is not installed
E: Unmet dependencies. Try using -f.
I have tried sudo apt-get -f install but due to no empty space, I am not able to successfully run it and getting the following error
Unpacking linux-image-4.4.0-137-generic (4.4.0-137.163) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-
137-generic_4.4.0-137.163_amd64.deb (--unpack):
cannot copy extracted data for './boot/abi-4.4.0-137-generic' to '/boot/abi-
4.4.0-137-generic.dpkg-new': failed to write (No space left on device)
I also tried to remove it using dpkg with the following code
dpkg --list | grep linux-image | awk '{ print $2 }' | sort -V | sed -n '/'`uname -r`'/q;p' | xargs sudo apt-get -y purge
I got the following error for the above command.
root@servername:/# dpkg --list | grep linux-image | awk '{ print $2 }' |
You might want to run 'apt-get -f install' to correct these:
linux-image-extra-4.4.0-112-generic : Depends: linux-image-4.4.0-112-generic
but it is not going to be installed
linux-image-extra-4.4.0-116-generic : Depends: linux-image-4.4.0-116-generic
linux-image-extra-4.4.0-119-generic : Depends: linux-image-4.4.0-119-generic
linux-image-extra-4.4.0-121-generic : Depends: linux-image-4.4.0-121-generic
linux-image-extra-4.4.0-124-generic : Depends: linux-image-4.4.0-124-generic
linux-image-extra-4.4.0-127-generic : Depends: linux-image-4.4.0-127-generic
linux-image-extra-4.4.0-128-generic : Depends: linux-image-4.4.0-128-generic
linux-image-extra-4.4.0-21-generic : Depends: linux-image-4.4.0-21-generic
Depends: linux-image-extra-4.4.0-142-generic but it is not going to be installed
Recommends: thermald but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I tried removing old kernels one by one but still no luck
root@servername:/# sudo apt-get purge linux-image-4.4.0-112-generic
I also tried with sudo rm -rf /boot/*-34.4.0-{112,116,119,121,124,127,128,21}-* but still no luck.
Does anyone knows how to resolve it?
Thanks in advance.
