I'm trying to install OpenCV4 as explained here
When I get to
sudo apt -y install libgstreamer0.10-dev libgstreamer-plugins-base0.10-dev
I receive
Reading package lists... Done
Building dependency tree
E: Unable to locate package libgstreamer0.10-dev
E: Couldn't find any package by glob 'libgstreamer0.10-dev'
E: Couldn't find any package by regex 'libgstreamer0.10-dev'
E: Unable to locate package libgstreamer-plugins-base0.10-dev
E: Couldn't find any package by glob 'libgstreamer-plugins-base0.10-dev'
E: Couldn't find any package by regex 'libgstreamer-plugins-base0.10-dev'
I have checked online and the packages are available here. I tried manually downloading and installing with
sudo apt install ./libgstreamer0.10-dev_0.10.36-1.5ubuntu1_amd64.deb
Which gives me
Note, selecting 'libgstreamer0.10-dev' instead of './libgstreamer0.10-dev_0.10.36-1.5ubuntu1_amd64.deb'
The following packages have unmet dependencies: libgstreamer0.10-dev : Depends: libgstreamer0.10-0 (= 0.10.36-1.5ubuntu1) but it is not installable Depends: libglib2.0-dev but it is not installable Depends: libxml2-dev but it is not installable Depends: gir1.2-gstreamer-0.10 (= 0.10.36-1.5ubuntu1) but it is not installable E: Unable to correct problems, you have held broken packages.
I'm new to Ubuntu (only used Manjaro). I don't understand why apt can't locate a package if it's on the website.
Cadoiz
  • 278
Matheus Leão
  • 191
libgstreamer0.10-dev is outdated in Ubuntu 18.04.
So, use newer version instead:
sudo apt install -y libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
This will surely work.
Blz
Olimjon
  • 7,522
Here is the same guide as above for Ubuntu 18.04
Cadoiz
  • 278
Matheus Leão
  • 191
