I cannot update the ubuntu-keyring package on my Ubuntu WSL.
I tried to run sudo apt update ubuntu-keyring and this is the command output:
Reading package lists... Done
Building dependency tree
The following packages will be upgraded:
ubuntu-keyring
1 upgraded, 0 newly installed, 0 to remove and 86 not upgraded.
Need to get 0 B/26.9 kB of archives.
After this operation, 6,144 B of additional disk space will be used.
Preconfiguring packages ...
(Reading database ... 91158 files and directories currently installed.)
Preparing to unpack .../ubuntu-keyring_2018.09.18.1-4_all.deb ...
Unpacking ubuntu-keyring (2018.09.18.1-4) over (2012.05.19) ...
dpkg: error processing archive /var/cache/apt/archives/ubuntu-keyring_2018.09.18.1-4_all.deb (--unpack):
trying to overwrite '/usr/share/keyrings/ubuntu-cloudimage-keyring.gpg', which is also in package ubuntu-cloudimage-keyring 2013.11.11
Warning: The postinst maintainerscript of the package ubuntu-keyring
Warning: seems to use apt-key (provided by apt) without depending on gnupg or gnupg2.
Warning: This will BREAK in the future and should be fixed by the package maintainer(s).
Note: Check first if apt-key functionality is needed at all - it probably isn't!
Warning: apt-key should not be used in scripts (called from postinst maintainerscript of the package ubuntu-keyring)
Warning: 'apt-key update' is deprecated and should not be used anymore!
Note: In your distribution this command is a no-op and can therefore be removed safely.
I also tried to download the ubuntu-keyring_2018.09.18.1-4_all.deb file and then install it using sudo dpkg --install ubuntu-keyring_2018.09.18.1-4_all.deb, but the same error shows up.
