After upgrading libnss-sysytemd library to the latest version 237-3ubuntu10.12, IPSEC/L2TP VPN connection is established but I cannot connect to outside of LAN. I found out the route table was not the same as the version 237-3ubuntu10.11. The difference is the order of the ip addresses. On 237-3ubuntu10.12, the order of the remote vpn ip address on route table is normal order but the VPN connection doesn't work well. On 237-3ubuntu10.11, the order is reverse order, then VPN connection works well.
But today, it happens again on the Starbacks WIFI even on the version 237-3ubuntu10.11. The route table is below.
237-3ubuntu10.11 on Starbacks WIFI
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         0.0.0.0         0.0.0.0         U     0      0        0 ppp0
default         _gateway        0.0.0.0         UG    20600  0        0 wlp58s0
10.27.40.0      0.0.0.0         255.255.248.0   U     600    0        0 wlp58s0
123.234.345.456 _gateway        255.255.255.255 UGH   0      0        0 wlp58s0
192.168.10.1   0.0.0.0         255.255.255.255 UH    0      0        0 ppp0
237-3ubuntu10.11 on the mobile network tethering.
456.345.234.123. _gateway        255.255.255.255 UGH   0      0        0 wlp58s0
I'm sure it's a bug of systemd. Has anybody reported this bug yet?
I'm using strongswan and xl2tp. It doesn't cause this problem anyway.
kirin
  • 277
The IP address with reversed ordering of the octets has a trailing dot, which indicates it is the significant part of a reverse DNS PTR record. See :
It's been fix with this solution.
sudo rm -f /etc/resolv.conf
sudo ln -s /run/systemd/resolve/resolv.conf /etc/resolv.conf
reboot
It was systemd bug.
https://bugs.launchpad.net/ubuntu/+source/systemd/+bug/1624320
Wrong nameserver set by resolvconf and NetworkManager
kirin
  • 277
