So as per the instructions, I've already added the ppa repo, and updated. But when I run:
# apt install dde
Reading package lists... Done
Building dependency tree
dde : Depends: dde-desktop but it is not going to be installed
Depends: dde-polkit-agent but it is not going to be installed
Depends: dde-dock but it is not going to be installed
Depends: dde-launcher but it is not going to be installed
Depends: dde-control-center (> 2.90.5) but it is not going to be installed
Depends: dde-daemon but it is not going to be installed
Depends: deepin-metacity but it is not going to be installed
Depends: deepin-wm but it is not going to be installed
Depends: startdde but it is not going to be installed
Depends: dde-session-ui but it is not going to be installed
Depends: deepin-notifications but it is not going to be installed
Depends: deepin-menu but it is not going to be installed
Depends: deepin-terminal but it is not going to be installed
Depends: dde-calendar but it is not going to be installed
Depends: deepin-system-monitor but it is not going to be installed
Depends: deepin-image-viewer but it is not going to be installed
Depends: deepin-screenshot but it is not going to be installed
Recommends: deepin-deb-installer but it is not going to be installed
Recommends: deepin-screen-recorder but it is not going to be installed
Recommends: deepin-voice-recorder but it is not going to be installed
Recommends: deepin-shortcut-viewer but it is not going to be installed
Is there a fix to this?
Edit: I have already tried the aptitude and synaptic methods. Aptitude reduced my dependencies by maybe 2, and synaptic says that I need to fix broken packages first. When trying the commands sudo dpkg -l | grep ^..r and apt-mark showhold I get no results.
Edit 2: I have tried the solutions from the second duplicate claim too, no luck.
