On 18.04 I've made a bootable pen drive. Now I don't need it. I want to remove the iso9660 partition.
sudo cfdisk /dev/sdb
I tried to delete (it makes) but when I want to save the changes, it fails.
Failed to write disklabel"
It isn't write protected (read-only is 0)
What else should I try?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
The non-interactive sfdisk can do this from the CLI:
sfdisk --delete /dev/sdb
See man sfdisk for details.
Seamus
  • 698
Use gnome-disks. That is the tool I use to remove, create and format partition in my USB drives.
You can easily install it with the command
sudo apt install gnome-disk-utility
Elder Geek
  • 36,752
You can use mkusb with a graphical user interface. You can select
  • 'restore to a Standard storage device', or
  • 'Wipe the first mibibyte'.
There are more details at the following links to Ubuntu help wiki pages
If mkusb cannot solve the problem, you can analyze it, and if you are lucky solve it, according to the following link
sudodus
  • 47,684
Rather than installing any extra software (and if you're comfortable with the command line), I would suggest using the dd command.
To wipe your USB fire up the gnome-terminal and type
sudo dd if=/dev/zero of=/path/to/usb
As was pointed out in the comments, you may be better off only wipe the MBR so as not to roast the USB
dd if=/dev/zero of=/dev/<path of data drive> bs=512 count=1 seek=0
Edit: Again as stated in comments MBR is in fact not 440 bytes :facepalm:
j-money
  • 2,516
  • 20
