My ubuntu is booting to the Grub command line.
I have Ubuntu 16.04 installed on my workstation. I haven't used it for the past ~2 weeks. I think 2 weeks ago I updated the software from the Ubuntu software popup thing, so that could be causing my present issue.
I've research into this problem but can't seem to find a solution to my specific problem. Specifically I looked at After update in Ubuntu 16.04 I ended up in GNU GRUB and appear to be stuck there And several others.
As you can see from the linked image, the only existing filesystem is on (hd0,2), but this is showing as a fat system which is not compatible with Ubuntu. Could my Ubuntu have been wiped somehow? Any advice on how to proceed?
