31
I usually do
sleep 4h; command
to execute a command after 4h. However, if that command requires sudo, it'll not work.
Is it possible to give sudo permission at the moment I'm running the sleep command?
R D
Poperton
  • 1,283
Use sudo to start a root shell where you run the commands:
sudo bash -c 'sleep 4h; command'
Every command running in the root shell runs with root permissions, which for sleep doesn’t hurt. If you need to run a command with user permissions in it, use sudo -u USERNAME COMMAND, e.g.:
$ sudo bash -c 'sleep 4h; sudo -u dessert whoami; whoami'
dessert  # whoami run as user dessert
root     # whoami run as root
Another approach would be to use sudo visudo to allow the command’s execution without root access, see: How to allow execution without prompting for password using sudo?
Note that depending on the command this may create a security flaw.
dessert
  • 40,956
21
Assuming you only want to run the process once (not, e.g. every 4 hours) then you can use atd
  1. Ensure that atd is running (in ubuntu that is /etc/init.d/atd status or better still systemctl status atd)
  2. At a terminal as root run your command as follows:
    # at now + 4 hours
    warning: commands will be executed using /bin/sh
    at> command
    at> CTRL-D
  3. If you want to run it every 4 hours you could also use cron (as root) with the following config in your crontab
    0 */4 * * * sh -c $'/path/to/command'
15
One way is to run via a shellscript with sudo permissions (and give the password, when you start the shellscript), if the shellscript is in the current directory,
sudo ./delayer 4h
where delayer can be a shellscript with the content
#!/bin/bash
sleep "$1"
command
Make it executable with
chmod +x delayer
and copy or move it to a directory in PATH if you wish.
If you want a more flexible shellscript, where you can select the command [line] to delay by entering parameter(s), you can try
#!/bin/bash
if [ $# -lt 2 ] || [ "$(whoami)" != "root" ]
then
 echo "Delay start of command, that needs 'sudo'
Usage:    sudo $0 <delay> <command line>
Example:  sudo $0 4h parted -ls"
 exit
fi
sleep "$1"
shift
Demo example (short delay, 5s, for demo purpose),
$ ./delayer
Usage:    sudo ./delayer <delay> <command line>
Example:  sudo ./delayer 4h parted -ls
$ sudo ./delayer 5s parted /dev/sdc p
[sudo] password for sudodus:
Model: Kanguru SS3 (scsi)
Disk /dev/sdc: 15,9GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name     Flags
 2      1049kB  2097kB  1049kB               primary  bios_grub
 3      2097kB  258MB   256MB   fat32        primary  boot, esp
 4      258MB   2274MB  2016MB               primary
 5      2274MB  12,5GB  10,2GB  ext2         primary
 1      12,5GB  15,9GB  3394MB  ntfs         primary  msftdata
sudodus
  • 47,684
Another way would be to start sudo interactive session with sudo -s (does not change directory) or sudo -i (changes current directory to root home directory) and then enter your commands (without sudo)
Ludwik
  • 151
