15
I want a machine that loses power to automatically reboot when power is available. I've looked around and haven't found a solution that works for 11.04.
Purportedly at one point you could do:
echo 'server_mode=1' > /proc/pmu/options
However, my install doesn't have a /proc/pmu folder. I assume this is still possible, where is the setting available?
EDIT:
If this isn't possible from the OS, is there a way to script these sorts of changes to BIOS or is this something that requires physical access to the machine on boot to manually edit the settings?.
sarwar
  • 253
That's not something you can control in your operating system. That's what the BIOS is for. In most BIOS setups there'll be an option like After power loss with possible values like Power off and Reboot.
RobinJ
  • 9,020
In the BIOS, look for something like "always restart on power failure"
In Ubuntu, edit /etc/default/grub.
sudo nano /etc/default/grub
and add
GRUB_RECORDFAIL_TIMEOUT=5
Then run:
sudo update-grub
This will make your machine display the boot options for 5 seconds before it boot the default option (instead of waiting forever for you to choose one).
MadMike
  • 4,275
  • 29
  • 50
Anton
  • 51
You would need a Uninterruptible Power Supply - Soft shutdown with an auto boot.
You might want to look here : http://www.apcupsd.com/ for a recommendation.
Ringtail
  • 16,285
