On an Ubuntu 16.04 (Xenial) system, I have installed a bunch of PPAs which installed packages with versions newer than the default repo packages, in an attempt to obtain some newer features that weren't available in the default repos.
Unfortunately, the system ended up being unstable. I removed all the PPAs, but now I have a whole bunch of packages that are ahead of the versions expected by the default repo packages and thus often incompatible with them.
An example of an error I'm getting with these new packages:
E: Can't find a source to download version '2.40.16-1~ubuntu16.04.1' of 'librsvg2-2:amd64'
E: Internal error: couldn't generate list of packages to download
$ apt policy librsvg2-2:amd64
librsvg2-2:
  Installed: 2.40.16-1~ubuntu16.04.1
  Candidate: 2.40.16-1~ubuntu16.04.1
  Version table:
 *** 2.40.16-1~ubuntu16.04.1 100
        100 /var/lib/dpkg/status
     2.40.13-3 500
        500 http://us.archive.ubuntu.com/ubuntu xenial/main amd64 Packages
I've been re-stabilizing the system by manually identifying and downgrading each of these packages to the repo version. In this case, for example, I'd do:
sudo apt install librsvg2-2:amd64=2.40.13-3
This seems to solve the problem for each individual package, but unfortunately there's a huge number of them so I'l like to find some automated solution that would downgrade them all in a batch.
Is there a way to do that?
The primary way I imagine is to somehow identify all packages that only have /var/lib/dpkg/status as their source. Of course, if there's any other way I'd be happy to learn it.
I have tried the solution from the suggested existing question and all I get is:
$ sudo apt-get -o Dir::Etc::Preferences=a_p dist-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Dun Peal
  • 245
I had a similar problem as the OP. I'm trying to install libsdl2-dev, which fails because
$ sudo apt install libsdl2-dev
The following information may help resolve the situation:
The following packages have unmet dependencies: libsdl2-dev : Depends: libasound2-dev but it is not going to be installed Depends: libegl1-mesa-dev but it is not going to be installed Depends: libgl1-mesa-dev but it is not going to be installed Depends: libgles2-mesa-dev but it is not going to be installed Depends: libglu1-mesa-dev but it is not going to be installed Depends: libmirclient-dev but it is not going to be installed Depends: libpulse-dev but it is not going to be installed Depends: libudev-dev but it is not going to be installed Depends: libxkbcommon-dev but it is not going to be installed E: Unable to correct problems, you have held broken packages.
This seems to be happening because a lot of installed packages don't have a repo.
$ sudo apt policy libxcb-present0
libxcb-present0:
  Installed: 1.13-2~ubuntu18.04
  Candidate: 1.13-2~ubuntu18.04
  Version table:
 *** 1.13-2~ubuntu18.04 100
     1.13-1 500
        500 http://ca.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
aptitude is able to automatically downgrade packages that are blocking installation of libsdl2-dev. Not exactly what OP is asking for. But was useful to me, and should be useful to others. For me, when I first run aptitude, it gives this as the first resolution
# aptitude install libsdl2-dev
<snip>
The following packages have unmet dependencies: libdrm-dev : Depends: libdrm2 (= 2.4.100-3~b~padoka0) but 2.4.101-2~18.04.1 is installed Depends: libdrm-intel1 (= 2.4.100-3~b~padoka0) but 2.4.101-2~18.04.1 is installed Depends: libdrm-radeon1 (= 2.4.100-3~b~padoka0) but 2.4.101-2~18.04.1 is installed Depends: libdrm-nouveau2 (= 2.4.100-3~b~padoka0) but 2.4.101-2~18.04.1 is installed Depends: libdrm-amdgpu1 (= 2.4.100-3~b~padoka0) but 2.4.101-2~18.04.1 is installed The following actions will resolve these dependencies:
 Keep the following packages at their current version:
  1. libdrm-dev [Not Installed]
  2. libegl1-mesa-dev [Not Installed]
  3. libgl1-mesa-dev [Not Installed]
  4. libgles2-mesa-dev [Not Installed]
  5. libglu1-mesa-dev [Not Installed]
  6. libsdl2-dev [Not Installed]
  7. mesa-common-dev [Not Installed]
Accept this solution? [Y/n/q/?]
Say no to this solution. A side note. It could be acceptable to just keep the current installed version. But I felt it was safer to stick with the official Ubuntu packages, or from repos that I want to use.
The next solution is to downgrade packages to versions that are part of know repos.
  Downgrade the following packages:
  1.  libdrm-amdgpu1 [2.4.101-2~18.04.1 (now) -&gt; 2.4.100-3~b~padoka0 (bionic)]
  2.  libdrm-amdgpu1:i386 [2.4.101-2~18.04.1 (now) -&gt; 2.4.100-3~b~padoka0 (bionic)]
  3.  libdrm-intel1 [2.4.101-2~18.04.1 (now) -&gt; 2.4.100-3~b~padoka0 (bionic)]
  4.  libdrm-intel1:i386 [2.4.101-2~18.04.1 (now) -&gt; 2.4.100-3~b~padoka0 (bionic)]
  5.  libdrm-nouveau2 [2.4.101-2~18.04.1 (now) -&gt; 2.4.100-3~b~padoka0 (bionic)]
  6.  libdrm-nouveau2:i386 [2.4.101-2~18.04.1 (now) -&gt; 2.4.100-3~b~padoka0 (bionic)]
  7.  libdrm-radeon1 [2.4.101-2~18.04.1 (now) -&gt; 2.4.100-3~b~padoka0 (bionic)]
  8.  libdrm-radeon1:i386 [2.4.101-2~18.04.1 (now) -&gt; 2.4.100-3~b~padoka0 (bionic)]
  9.  libdrm2 [2.4.101-2~18.04.1 (now) -&gt; 2.4.100-3~b~padoka0 (bionic)]
  10. libdrm2:i386 [2.4.101-2~18.04.1 (now) -&gt; 2.4.100-3~b~padoka0 (bionic)]
There you go. Now at least the orphaned packages that are blocking the install of libsdl2-dev have been downgraded to versions that are known to repos.
