I have:
  • Operating System: Kubuntu 18.10
  • KDE Plasma Version: 5.14.5
  • Qt Version: 5.11.1
  • KDE Frameworks Version: 5.52.0
  • Kernel Version: 4.18.0-15-generic
  • OS Type: 64-bit
  • Processors: 4 × Intel® Pentium® CPU 4415U @ 2.30GHz
  • Memory: 11.5 GiB of RAM
$ sudo apt-get install pulseaudio
Reading package lists... Done
Building dependency tree
 pulseaudio : Depends: libpulse0 (= 1:12.2-0ubuntu4) but 1:12.2-5~bionic1 is to be installed
              Depends: pulseaudio-utils but it is not going to be installed
              Recommends: rtkit but it is not going to be installed
$ apt-cache policy libpulse0
libpulse0:
  Installed: 1:12.2-5~bionic1
  Candidate: 1:12.2-5~bionic1
  Version table:
 *** 1:12.2-5~bionic1 100
        100 /var/lib/dpkg/status
     1:12.2-0ubuntu4 500
        500 http://dk.archive.ubuntu.com/ubuntu cosmic/main amd64 Packages
Zanna
  • 72,312
newcat1000
  • 1,594
The 1:12.2-5~bionic1 version of libpulse0 is not from official repositories. You probably installed it from somewhere else.
I suggest downgrading the version using Synaptic.
Select the package and then use "Package" menu to set the correct 1:12.2-0ubuntu4 version.
Pilot6
  • 92,041
