There is lxd-3.0.3 unprivileged (containers with uid shift started by root) on Ubuntu-18.04 (amd64). In container there is Ubuntu-16.04.5 (amd64). How to configure pptpd on it? It seems that there is problem with ppp0 interface. It is not available.
Here if fragment of log:
Feb 13 19:21:22 blabla100 pppd[25943]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
Feb 13 19:21:22 blabla100 pppd[25943]: Couldn't open the /dev/ppp device: No such file or directory
Feb 13 19:21:22 blabla100 pptpd[25927]: modprobe: ERROR: ../libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file '/lib/modules/
Feb 13 19:21:22 blabla100 pptpd[25927]: modprobe: FATAL: Module ppp_generic not found in directory /lib/modules
Feb 13 19:21:27 blabla100 pptpd[25927]: /usr/sbin/pppd: You need to create the /dev/ppp device node by
Feb 13 19:21:27 blabla100 pptpd[25927]: executing the following command as root:
Feb 13 19:21:27 blabla100 pptpd[25927]: mknod /dev/ppp c 108 0
Feb 13 19:21:27 blabla100 pppd[25935]: You need to create the /dev/ppp device node by
So I guess I must create /dev/ppp on host, but how to allow to access it only in this container, not other containers.
