I was cyber-attacked by someone from China and they managed to install Yam (crypto mining) on my Ubuntu 14.04 server.
I managed to close their ssh access through the public IP. and I have remedied the damage they did. Except for two things that have me confused still.
1- I can not edit /etc/rc.local from root. they have a script in there to adduser 'setup' with root permissions. I cant edit the script although it is owned by root and has the permission. I get permission denied. I can edit other files so the filesystem is not read only.
2- Every time I log in via ssh, I get the welcome message, then "You have mail" followed by a huge number of permission denied errors like this:
    You have mail.
    find: `/var/log/speech-dispatcher': Permission denied
    find: `/var/log/samba/cores': Permission denied
    -bash: /var/log/Xorg.1.log.old: Permission denied
    -bash: /var/log/apache2/error.log.43.gz: Permission denied
    -bash: /var/log/apache2/error.log.14.gz: Permission denied
    -bash: /var/log/apache2/access.log.44.gz: Permission denied
    -bash: /var/log/apache2/error.log.13.gz: Permission denied
    -bash: /var/log/apache2/crm65.com-access_log: Permission denied
    -bash: /var/log/apache2/access.log.9.gz: Permission denied
    -bash: /var/log/apache2/error.log.36.gz: Permission denied
    -bash: /var/log/apache2/error.log.16.gz: Permission denied
    -bash: /var/log/apache2/error.log.11.gz: Permission denied
    -bash: /var/log/apache2/testcrm-error.log: Permission denied
    -bash: /var/log/apache2/error.log.46.gz: Permission denied
    -bash: /var/log/apache2/error.log.18.gz: Permission denied
    -bash: /var/log/apache2/access.log.45.gz: Permission denied
    -bash: /var/log/apache2/access.log.34.gz: Permission denied
    -bash: /var/log/apache2/vtigercrm-access.log: Permission denied
it basically goes through the whole /var/log directory.
I am not sure what is happening there.
ANY help is appreciated!
Sam
  • 71
rc.local was set to immutable by the hacker.
Used chattr to change the file attributes and I was able to edit it.
As for the permission denied errors upon login, the hacker inserted lines into the motd scripts to delete log files to hide any trace of his yam program. removing those lines resolved the problem.
I hope that helps anyone with a similar problem. I recommend you edit your ssh/iptables to allow only certain IPs to log in via ssh to avoid such problem, I learned the hard way.
Sam
  • 71
