How can I install Epson L3150 ink tank printer in Ubuntu? I failed to install using the deb file given in the site
Follow this link, in the search box type "L3150" and in the dropdown menu choose "Linux".
Press "Download" next to "ESC/P-R Driver (generic driver)" and the "Epson Scan 2" scanner driver.
Press "Accept" and then download the driver file named
epson-inkjet-printer-escpr_XXXX-1lsb3.2_amd64.deb(even if your processor is not AMD) where instead of XXXX will be the current version number. Similarly you will download a .deb file for the scanner.Install using GDebi:
First install GDebi with the command sudo apt install gdebi.
First just try to open the file, which will open GDebi's gui, and click install.
If that doesn't work, open a terminal, browse to appropriate folder, and run
sudo gdebi epson-inkjet-printer-escpr_XXXX-1lsb3.2_amd64.deb (don't forget to replace XXXX with version number).
Similarly install the scanner driver.
- Go to Printers, press
Add, let it find your printer (note whether it is connected directly via USB or via the network) and proceed in the obvious way to set the printer.
- 38,814
- 287
