My goal is simple: to get the same Kana input layout as Windows on a US English keyboard. By default, the Kana input layout of iBus Mozc is very different from that of Windows.
After reading this question, I thought it could be achieved by changing the keyboard layout value. The aforementioned question only showed default and jp. Mine also had been set to default, so I tried jp. The result was almost what I wanted, with just one deal-breaker: I cannot type "ろ". I searched Google Image, and found that real Japanese keyboards have a dedicated "ろ" key, which US English keyboard does not have. On Windows, I press the tilde key (the key left to the "1" key) to type "ろ", but with Mozc jp, that key just toggled the input mode.
I thought I could try other layouts than jp, but after searching Google, I could not find the list of possible values. What are the possible values? Or, specifically, what is the name of a layout that is just like jp, but lacks the dedicated "ろ" key? Or, if there is no such layout, is there any way to make the tilde key type "ろ" just like Windows?
comparison US/JP
Japanese JIS keyboard layout has one key column more, compare to the US layout. We get ろ on ~ the US keyboard layout, but it usu on the left of Shift_R on JIS layout. Be aware of your keyboard, don't change setting for the OS, unless you have both.
84 keyboard
I have another interesting example, the mobile Japanese keyboard likewise 84 keys has some functions on the same key should be used with Fn or other modifier keys, so that Hankaku/Zenkaku key and Tilde key are at the same place (on the left of 1), that gives you strange result, I think.
To fit the Japanese keyboard layout to your particular keyboard layout,
sudo dpkg-reconfigure keyboard-configuration
Then, still you probably can't type some letters which on the last column of Japanese layout or you need to solve the puzzle which goes where, If you are using US keyboard layout, you should set the layout to US or default.
Open Imput Method Configuration by System Settings > Text Entry > select Mozc and click 'wrench' or im-config
Input Method configuration
You can set the toggle key combination here.
Mozc configuration
You can set what kind of input mode Roman/Kana on Mozc configuration, that is inside of Mozc engine.
Finally,
ろぬふあうえおやゆよわほへ
たていすかんなにらせ゛゜む
ちとしはきくまのりれけ
つさそひこみもねるめ
These are the letters when I pressed the keys from left to right, 1st row to 4th row. Note: my mother tongue is Japanese, sorry about my strange English. And I hope you get it.
