I have enabled location services. I'm using Ubuntu 18.10 on a desktop that doesn't have a GPS. On Windows 10, I was able to set the location manually with an address.
You will have to manually create the configuration directory as it's moved in this version, though falling back in case the directory does not exist:
mkdir ~/.config/redshift
Use your favorite text editor to create and edit the config file, I will use VS Code here:
code ~/.config/redshift/redshift.conf
Example config file heavily commented.
; Global settings
[redshift]
; Set the location-provider: 'geoclue2', 'manual'
; type 'redshift -l list' to see possible values.
; The location provider settings are in a different section.
location-provider=manual
; this has changed since this version in favor of randr
; formerly vidmode has been mostly used from what I read
adjustment-method=randr
; Disable the smooth fade between temperatures when Redshift starts and stops.
; 0 will cause an immediate change between screen temperatures.
; 1 will gradually apply the new screen temperature over a couple of seconds.
fade=0
; Solar elevation thresholds.
; By default, Redshift will use the current elevation of the sun to determine
; whether it is daytime, night or in transition (dawn/dusk). When the sun is
; above the degrees specified with elevation-high it is considered daytime and
; below elevation-low it is considered night.
;elevation-high=3
;elevation-low=-6
; Custom dawn/dusk intervals.
; Instead of using the solar elevation, the time intervals of dawn and dusk
; can be specified manually. The times must be specified as HH:MM in 24-hour
; format.
;dawn-time=6:00-7:45
;dusk-time=18:35-20:15
; The location provider and adjustment method settings
; are in their own sections.
; Configuration of the location-provider:
; type 'redshift -l PROVIDER:help' to see the settings.
; ex: 'redshift -l manual:help'
; Keep in mind that longitudes west of Greenwich (e.g. the Americas)
; are negative numbers.
[manual]
lat=00.8
lon=00.1
; Configuration of the adjustment-method
; type 'redshift -m METHOD:help' to see the settings.
; ex: 'redshift -m randr:help'
; In this example, randr is configured to adjust only screen 0.
; Note that the numbering starts from 0, so this is actually the first screen.
; If this option is not specified, Redshift will try to adjust _all_ screens.
[randr]
screen=0
This will Work for the Location. Update the location manually
[manual]
lat=00.8
lon=00.1
