initially i could able to log in phpmyadmin before i excecute the installtion of wordpress using http://127.0.0.1:8888/phpmyadmin .But after i had install wordpress environment ,i have issue on wordpress and phpmyadmin
wordpress issue :
<?php
 * Front to the WordPress application. This file doesn't do anything, but loads
 * wp-blog-header.php which does and tells WordPress to load the theme.
 * @package WordPress
 * Tells WordPress to load the WordPress theme and output it.
 * @var bool
define('WP_USE_THEMES', true);
/** Loads the WordPress Environment and Template */
require( dirname( __FILE__ ) . '/wp-blog-header.php' );)
phpmyadmin :
Not Found
The requested URL /phpmyadmin/index.php was not found on this server.
Apache/2.4.18 (Ubuntu) Server at 127.0.0.1 Port 8888)
Please help ,i m a newbie on linux
vidarlo
  • 23,497
Ed Tan
They are 2 different sites. I will try to explain this as best as I can. PhpMyAdmin is held in one location and when you loaded WordPress it writes it's own location. You need to go into the apache sites and create a new site to point to the the PhpMyAdmin directory.
I totally butchered that explanation. But I am pretty sure that is what happened.
It has been awhile since I worked with WordPress. So I am trying to remember all this. After closer look at my apache config. There is a conf file in /etc/apache2/conf-enabled/phpmyadmin.conf with the directive Alias /phpmyadmin /usr/share/phpmyadmin .
This is supposed to allow any virt server dir "phpmyadmin" and direct it to the phpmyadmin directory. WordPress is probably overriding that directive.
I would create a new site in /etc/apache2/sites-enabled/ (note that you really should create it in available then link it) and then point it back to the default (/var/www/html/) and set it on a different port. And you should get it back.
dewd
  • 47
According to this guide, you just need to add the line:
sudo ln -s /usr/share/phpmyadmin /var/www/html
