I found the menuentry/subentry that I wanted to use, as you can see here: https://gyazo.com/b73fa2308145caaed7959a95d71a4bc8
I then changed this in /etc/default/grub to this: GRUB_DEFAULT=1>0
I updated grub with: sudo update-grub
And then rebooted the system with: sudo reboot
It still loads into the same old kernal.
I am using Ubuntu 16.04.
According to the documentation the format is one of
  • GRUB_DEFAULT="Previous Linux versions>Ubuntu, with Linux 3.2.0-18-generic-pae"
  • GRUB_DEFAULT="Previous Linux versions>0"
  • GRUB_DEFAULT="2>0"
  • GRUB_DEFAULT="2>Ubuntu, with Linux 3.2.0-18-generic-pae"
Your screenshot instead shows
1>0 Ubuntu, with....
It lacks the GRUB_DEFAULT= part, the quotes "…", and is a mixture of both numeric and textual item selection. Try
GRUB_DEFAULT="1>0"
PerlDuck
  • 13,885
