I tried to install R on my Ubuntu 16.04 LTS. However, I have errors that I can not solve for several hours. I first tried to install the bionic version and after the xenial version. Both methods produced the same errors. I do not know which one to use, it's confusing for me. I followed this procedure to install it.
sudo echo "deb http://cran.rstudio.com/bin/linux/ubuntu xenial/" | sudo tee -a /etc/apt/sources.list
gpg --keyserver keyserver.ubuntu.com --recv-key E084DAB9
gpg -a --export E084DAB9 | sudo apt-key add -
sudo apt-get update
sudo apt-get install r-base r-base-dev
When I execute sudo apt-get install r-base r-base-dev, I get the following errors :
sudo apt install r-base r-base-dev
Reading package lists... Done
Building dependency tree
r-base : Depends: r-base-core (>= 3.5.2-1bionic) but it is not going to be installed
Depends: r-recommended (= 3.5.2-1bionic) but it is not going to be installed
Recommends: r-base-html but it is not going to be installed
r-base-dev : Depends: r-base-core (>= 3.5.2-1bionic) but it is not going to be installed
I have tried several solutions on different topics but they have no effect on the problem.
Thank you in advance for your help.
